Druide Antidote does not work
Druide Antidote Not Working
Hello,
The antidote Druide extension (https://www.antidote.info) (1000.2.85) (ID: CCHFIGJCPJMCLMMPDKEOCKLPNJE) does not work on BRAVE BROWSER (relaese latest version) and (Nightly Builds) and works well on Chrome (Screenshot problem on Brave)
Can you please fix the problem
Thanks
Sorry, I use a French/English online translator
Capture d’écran 2022-07-14 092100
Message window - translation thanks to ‘deepl.com
Unable to communicate with Google Chrome
To establish communication:
  • refresh the web page or restart Google Chrome
  • please check that JavaScript execution is allowed in Google Chrome preferences
Error code: 6010
Antidote Druide Extension User Guide
You may need to Disable (and remove) other Extensions, so that the Antidote Druide Extension is alone - for testing.
All of the following steps, assume that you normally wish to have / leave Brave Browser > Shields: UP
When visiting: ‘https://www.antidote.info’, set the site-specific Shields (Lion icon - near right end of URL address field) settings:
  • Shields: UP for this site
  • Trackers & ads blocked (Aggressive)
  • Cross-site cookies blocked
  • Fingerprinting blocked (Strict)
Global Shields Settings:
In a Brave Browser > New Window, go to: brave://settings/shields
  • Disable: Auto-redirect AMP pages (AMP - Google’s Accelerated Mobile Page)
  • (Alternate setting for older Brave Browser versions, try: Disable Enable De-AMP at brave://flags)
  • Disable: Prevent sites from fingerprinting me based on my language preferences
  • Trackers & ads blocking: Aggressive
  • Enable: Upgrade connections to HTTPS (HTTPS EVERYWHERE toggle switch)
  • Enable: Block scripts
  • Block fingerprinting (aka Fingerprinting blocking): Strict, may break sites
  • Block cookies (aka Cookie blocking): Only cross-site
In a Brave Browser > New Window, go to: brave://settings/cookies
Scroll down that settings page, to Sites that can always use cookies
Click the Add button
Enter [*.]antidote.info as the site . . . but Do Not Enable:
  • Current Private session only
  • Including third-party cookies on this site
Repeat those steps for the following entry:
  • [*.]youtube.com
Next, go to brave://settings/content/javascript
Scroll down that javascript settings page to Allowed to use javascript
  • [*.]youtube.com
Note, if you want to Disable HTTPS ONLY, go to: brave://settings/security
  • Disable: Always use secure connections (HTTPS ONLY toggle switch)
Note, while at: brave://settings/security you might also:
  • Disable: Use secure DNS
Next, go to: brave://settings/clearBrowserData
For tab Basic:
  • Set: Time range:All time
  • Enable: Browsing history
  • Disable/Enable: Cookies and other site data (Enable, Signs you out of most sites)
  • Enable: Cached images and files
Click on the ‘Clear data’ button.
(The ‘Clear data’ button also saves the selections.)
If a connection problem persists, when visiting: ‘https://www.antidote.info’, set the site-specific Shields (Lion icon - near right end of URL address field) settings:
  • Trackers & ads blocked (Standard)
  • Fingerprinting blocked (Standard)
