I want to use extra filters so I use Ublock Origin extension in addition to Brave Shield.
And sometimes it catches more.
Can I use brave reward system and recieve brave ads with Ublock Origin extension or they will be blocked. ?
If It blocks them.Can U help me to make whitelist of brave ads for extension.Couse I want to be part of Brave Rewards with using Ublock Origin.
I have uBlock Origin in Advanced mode with 3rd-party scripts and frames blocked globally, and I found that I was not receiving Brave Rewards ads. I had to add “support.brave.com” to my Trusted Sites to get Brave Rewards ads.
thanks, will try that!
