Does Direct Links are Valid for Referrals?
Does Direct links are valid for Refferal ?
Normal Referral link is
Brave.com/xyz
If user installed from this direct link is valid is it counted on dashboard of pub account ??
Direct link eg :
https://laptop-updates.brave.com/download/XYZ
If users downloads from the direct link is that would consider as referral link or not
@Mr.M Yes, direct links are considered as Referral links.
Thanks!
This One Is Direct Link ! You said it would be Consider as Refferal link am I right ! Cross checking twice thanks for the replay by the way !
