Display issue on Brave
**Description of the issue:**Hello, for some time now, I’ve been having display issues with Brave on my laptop, while I don’t have this problem on my desktop PC. Here’s what happens when I go to Brave’s settings.
And here’s what it looks like on some websites
It doesn’t happen every time, as sometimes after several attempts, the page displays correctly. The browser is up to date, and so are the latest Windows updates.
Thanks in advance.
Looks like a Graphics Acceleration issue.
Can you please the following:
  1. Ensure that you have a shortcut for Brave on your desktop
  2. Right-click that shortcut and go to Properties
  3. In the Target field, after the last quotation mark, type in --disable-gpu
  4. Click Apply then OK
  5. Launch Brave using that shortcut
Does the issue persist after doing this?
It seems the issue is fixed ! It was indeed the hardware acceleration causing the problem.
Thank you, and if the issue comes back, I’ll reach out again.
Glad that did the trick. Yes please let us know if the issue reappears.
