So I went to Discord.com (I never use the standalone program since it’s slower than the web version especially on a 2c2t 4gb ram laptop) and it won’t load at all, I’ve tried wiping the cookies and logout&login but nothing worked, and I tried it on another browser and it works.
since I use brave as my default I don’t want to switch browser, and I believe that this is a problem on the browser’s end. I believe that a feature that is vital for Discord is disabled on Brave, any help?
For me it works normally.
Try disabling extensions.
If that doesn’t work, try creating new discord account or reinstalling Brave.
Tip: you can use discord as a webapp so it will still run in Brave but in separate window just like a real app
