Difference between Brave Report and Uphold report
I found a big difference between the information that Brave Rewards | Creators shows as “Last Deposit” and the Uphold information about that same transaction, is less than half !
This are the print screens from both platforms:
Screenshot from 2020-08-09 15-37-51
Brave Version : Version 1.11.104 Chromium: 84.0.4147.105 (Official Build) (64-bit)
Thanks
Are you sure it’s all transactions in Uphold? Payment is happens in separate transactions – for each channel and other for referral.
Then why are they informing about LAST Deposit in Brave if it was not completed ?
Anyway, if that is the case, how much should I wait ?
Also, I’m not sure if this is the right medium for this kind of problems. How can I contact Brave directly ?
Thanks @eljuno !!!
