Briefly describe your issue:
**What Operating System and Brave version are you using (Menu --> About Brave)?**Android 12 Brave 1.37.116 Chromium 100.0.4896.127
**Is your browser wallet currently verified? (yes/no)**Yes
**What date did you verify your wallet?**more than 6 Months
**Have you been able to successfully receive payments in the past?**Yes, i received last month also
**Are you using a VPN? (yes/no)**No
**Are you in a supported region (see here for list of supported regions)?**Yes, India
**Does your device pass the SafteyNet check (Android only)?**Yes
**Have you manually turned off Auto-contribute on all of your devices linked to Uphold??**No
