Dependent Dropdown values are not showing on Browser
- Go to Any webpage where two dependent dropdown fields present
- Select Parent dropdown field
- Check dependent Dropdown value is visible
Dependent dropdown value should be visible.
v 1.48.171
In Console, system is showing error: “TypeError: Cannot read properties of undefined”
This is working fine in other browsers.
