Delete password info and any other info from brave
Description of the issue: I’d like to get rid of the information I imported over from Chrome and have any info I’ve saved to Brave deleted. I know there’s not really an account on a browser but I want to make sure the passwords that I imported will be removed so it’s as if I never downloaded Brave in the first place.
Expected result: Not having to delete each imported password from Chrome one by one.
Brave Version( check About Brave): 1.15.72
@surgebot,
Go to Menu --> Additional Settings --> Rest Settings to restore the browser to a fresh, default installation without any data.
You can also go to Menu --> History --> Clear browsing data and clear all browsing data for All time.
Thanks for the reply!
I did what you said and it cleared up a lot except for my passwords that are under the autofill tab. How can I get rid of that?
@surgebot,
Menu --> History --> Clear browsing data --> [Advanced] – check all the boxes here that are relevant (or just the Passwords and other sign-in data option if that’s all that is left to delete), make sure you change the timeframe drop down to All time, then Clear data.
That did it! Thank you!!!
