Default zoom setting ignored
Win 11
Version 1.64.113 Chromium: 123.0.6312.86 (Official Build) (64-bit)
I’ve set the default zoom to 67% but most pages open at 100% some at 90%.
Removed zoom extension – no change
This, coupled with inability to customize toolbar (like firefox) and the fact that I can’t reorder the extensions in the dropdown means that
I’m going to have to use a different browser until these things are fixed. As it stands it’s simply to clumsy and inefficient to use as my primary browser.
I thought that someone might care to address these things before they work on all those thing that clog the home page (and which I immediately disabled).
And, btw, Brave’s spell ckecker is totally lame. type “thay” it doesn’t offer they as one of the option :frowning:
Can you try testing this in a fresh profile and tell me if you get the same results? I’m wondering if the zoom (I’m assuming you mean an extension that assists with the zoom functionality, not the actual “Zoom” extension) extension you used left some weird data in your profile which is causing the odd behavior. I just tested this on my Win 10 and macOS system and am getting consistent results.
Pretty sure I will be changing browsers, too. It is inconceivable to me that, with nearly 1/4 of the 21st century now gone, I have to put up with some programmer’s arbitrary zoom increments. There’s one extension out there that claims to be able to do this, but it’s buggy. You know, the Voyager spacecraft are both still working. But this browser has gone with some business model that doesn’t include user convenience for obvious stuff.
