Default search engine list has only limited options available in the settings. It would be great if you could provide more options or a choice to set up custom search engine.
Personally, I want to have ‘Dsearch’ as my search engine.
I’m afraid such search engine will be listed soon since its not that many people use it, i even heard it just now. But for the meantime you can just manually access the site url and use the search engine.
@amalnathsathyan You can ask Dsearch team to support “OpenSearch”. Any search engine that support “OpenSearch” will be listed under “Recently visited” and you can set it as default from there.
You get PRE tokens for every search. Brave plus Preasearch as search engine is a deadly combo ! You may try it here ; -
