1st time on here, I haven’t found a solution so I made an account so someone can tell me one. Otherwise, I can no longer use Brave. Below I just copied and pasted this topic as it is the exact same but it is closed without a solution from what I can tell.
When using a touchscreen laptop, if you close Brave through the x icon in the top right and then go back into Brave, your mouse will disappear
- (requires touchscreen laptop) close Brave through the X icon in the upper righthand corner of the screen
- open Brave using a touchpad/mouse and the cursor should disappear when you hover over/ click into Brave.
Mouse should disappear when hovering over/ clicking into Brave
every time you attempt the bug
Brave Version(about:brave):
Version 0.63.48 Chromium: 74.0.3729.108 (Official Build) (64-bit)
yes
has been around on older versions, but I didn’t know how to reproduce the result.
