Hi community, I’m having a different problem than other posts I’ve seen. My issue is that when I enter my credit card information and click save it, shows that it saved but then when I exit out of brave and login say, for example, the next day, all the information is deleted regarding credit cards. This is a big problem for me because I use that information regularly and it’s a burden re-entering it all the time. Previously this feature used to work perfectly for me. but it no longer saves. any help trouble shooting?
@Benjamin-J-Onelove do you have any data set to be cleared “on exit” (Settings --> Delete browsing data --> On exit)? Namely the Autofill form data option:
hi thanks for your reply. yes i do have that box checked. what should i do?
i just unchecked those boxes, ill see if that helps
Browski,
That totally worked. thank you. brave community is great.
@Benjamin-J-Onelove Glad you were able to resolve the issue. Have a great day!
