This is a problem I have not encountered before but the address aigwomensopen.com produces a faulty display on the screen in that the screen does not light up properly so cannot be seen clearly. This problem is not apparent on other browsers.
@andrewbacon, just a heads-up: when you encounter a website that doesn’t let you interact with it or seems phased out, it’s often because it’s trying to display a cookie consent banner or an ad. Disabling Shields will likely reveal the cookie consent banner, like this:
Once you accept the consent, you can turn Shields back on, and the site should work fine. However, this is not the usual behavior. If you encounter content that requires disabling Shields to interact with it, please report it. Reporting helps the team update filters so that sites can’t block access unless you interact with their notices.
If you post about issues in the future, it would be helpful to select the appropriate category for your topic and provide all the details requested in the template. For example, this should ideally be under Ad-Blocking, which I’ll move it to. You can learn more on how to choose categories and complete the template at PSA: Current FAQ - #46 by Saoiray. Thanks.
Thanks
very helpful
A
@fanboynz wanted to tag you in on this if you get time to check on it. Thanks
