How to I edit the dropdown values here?
IE: Say I want to remove the value “Gloves”
Brave version:
Version 1.43.88 Chromium: 105.0.5195.68 (Official Build) (64-bit)
Brave version:
I think if you use the down-arrow key to select it, then press Shift+Del, it should remove it from the autocomplete list.
Awesome. that worked. thanks!
