Container exposure during "Delete browsing data" outside the container
Question re: Container site-data-isolation from deletion operations outside it.
In Brave desktop browser on Windows 11, I recently have begun using containers, but I would like to “clean up” any “general” site data that was saved in the browser before I enabled containers.
I am concerned that deleting site data, when outside the containers, may also delete data in them.
Is this the case?
If so, is there a way to backup container site-data and restore just container site-data to it’s proper container afterward?
I can’t find an answer anywhere and would appreciate advice.
But please mention if you are Brave staff and, if not, whether you are certain about your advice. Thanks.
Also, this forum system has become much more complicated since the last time I was in it. If I am placing this question in the wrong place, please let me know.
Brave Version( check About Brave): Windows version 1.94.121
@Virtex22
According to Brave Search (Answer with AI):
To clean up general site data without affecting Containers in Brave on Windows 11, you must use the Site Settings interface rather than the global “Delete browsing data” menu. Using the global menu while containers are active can lead to unintended data exposure or deletion across container boundaries due to how the browser handles scope.
The Safe Method:
  1. Navigate to brave://settings/content/all in your address bar of a Brave Browser New Window (not a Private Window).
  2. Use the search field (upper-right area of the settings page > “Filter sites on page”) to find specific domains you wish to clear.
  3. Click Delete data button or Delete Displayed Data button to remove cookies and site data for that specific site only.
Why this works:
  • Granular Control: This method targets data by domain, bypassing the global “Delete browsing data” tool which often struggles with container isolation.
  • Container Safety: Data stored within containers is treated as separate from the default profile’s “general” storage. By deleting data via the site details view for the default profile, you only remove data from the non-container context.
  • Avoids Global Risks: The global “Delete browsing data” tool has known issues with clearing individual site data correctly and may inadvertently affect container data if not scoped properly.
Additional Note:
If you want to ensure no residual data remains, you can also use Developer Tools:
  1. Right-click on a page and select Inspect.
  2. Go to the Application tab.
  3. Under Storage, click Clear site data.
  4. This affects only the currently active site and window context, leaving container data untouched.
Do not use brave://settings/clearBrowserData with “All time” selected if you have active containers, as this is the primary source of cross-container data deletion risks.
Is there a way to backup container site-data and restore just container site-data to it’s proper container afterward?
NO.
Brave’s Containers (introduced in v1.92, July 2026) isolate cookies, local storage, IndexedDB, and cache per container, but the browser provides no per-container export or import mechanism. The only backup path that covers container data is a full profile backup:
  1. Close Brave.
  2. Copy the entire C:\Users\<you>\AppData\Local\BraveSoftware\Brave-Browser\User Data folder.
  3. To restore, replace the folder (or the relevant profile subfolder) while Brave is closed.
This restores all containers together with the rest of the profile - you cannot cherry-pick just one container’s site data and drop it back into the correct container later.
(AI-generated answer. Please verify critical facts.)
PS. I am not Brave Support Staff.
