I can’t connect to Opensea.io using the Brave wallet. I was able to connect using metamask. Is there setting procedure that I have to follow?
Hi @jkng0302 , happy to help you!
Please try these steps so we can rule out some things:
- Go to brave://settings/wallet and make sure your
Default cryptocurrency walletis set toBrave Wallet
- Open up your Brave Wallet Panel and make sure your
Networkis set toEthereum Mainnet
- Make sure you Brave Wallet is unlocked and go back to
opensea.ioand click theWallet Iconat the top right of the page, then selectMeteMask.
- You should be prompt to select an account to connect, Click
Nextand thenConnect
- Should be connected now
Yes. It worked. I think the key was setting the wallet to Ethereum network. Thank you very much.
