Common Rewards Issues (Work in Progress)
This is a short list of some of the most common Rewards issues we see and what they mean if you encounter them. This document is a work in progress and we will continue to update it with additional information.
Balance on Uphold does not match wallet balance (w/o verified wallet)
This issue is known and we are currently investigating the issue where the browser balance is not the same as the balance displayed in your Uphold account.
However, there is one case in which this may be expected. Please note that there is currently a lifetime 4 device connection limit to a single Uphold account. (Note: This is currently a lifetime limit, meaning that even if you have since disconnected or uninstalled a previous installation of Brave, this still counts toward your lifetime limit.)
Any verified wallet or connection to an Uphold account past 4 will not receive Brave Ads payouts, and existing BAT earnings will not be transferred over. In these cases, the BAT will remain in the browser only.
Uphold debit to @BravePublishers/BAT Auto-Contributed without consent
This is an issue that has occurred before and has since been resolved. If you have already updated to the latest Brave build and have still had your BAT debited/contributed without your consent, please send a DM to @mattches, @steeven-AWAY-AUG17 or @Aa-ron with the information in the General tab on your brave://rewards-internals page.
Please include “Auto-Contribute error” in the subject line, along with the amount of BAT that was debited from your account, as well as a screenshot of the transaction on your Uphold account (if applicable).
BAT not being transferred to Uphold account
Note that Rewards for viewing Brave Ads are paid out on a monthly basis - they are not paid out in real time (as ads appear). Users will be paid out for viewing ads on the 5th of every month. You can see your estimated earnings and how many ads you’ve seen for the month by going to Settings → Brave Rewards and observing the Ads section:
Balance decreases (or disappears) after wallet verification
This is likely due to the Duplicated BAT display bug. It should be resolved when you verify your wallet and is a purely cosmetic issue – no rightfully earned BAT is lost.
“Wallet Unreachable” error (w/verified wallet) OR “Uh oh! Rewards server not available” error
This could be due to a server outage or server error on the Rewards side. However, it can also be caused by a blocked connection to the Rewards server or an authentication [mix up] – try disconnecting, reconnecting verified wallet in Rewards panel. If you’re connected to a VPN when you see this, try disabling the VPN connection and test to see if you get different results.
Backup/Restore wallet did not restore full amount
As of v1.3, the backup/restore feature can only restore your estimated pending earnings, and not your current BAT balance. This is because your BAT balance is calculated locally and is no longer related to your recovery key. If you’d like to secure all of your funds in the case of clean installing the browser or switching to a new device, and have other benefits such as adding, withdrawing and transferring funds, we recommend verifying your wallet and connecting your wallet to an Uphold account.
Rewards Payout Issue
Not receiving Ads and I can Assure that I am not using a VPN :)
Still not getting Ads
I lost BAT for no reason
"Uh oh. Your wallet is unreachable"
And stillllll no answerrr to my problem
How to restore Brave Verified Wallet after changing the PC
BAT on Android Browser Not Going Into Uphold
Uninstalled and reinstalled. All my rewards are gone
Issue recovering wallet for brave rewards on new machine
Can I move a profile to another machine?
Haven't gotten ads in 2 hours
Brave grant reward bat points missing after reinstall
BAT on Rewards but Not appear on Uphold
This month's payment issue for 5 devices
Rewards on Android aren't being sent to Uphold wallet
My BAT is not moving into my uphold account that I set up on JUNE 5th
The funds in your Brave wallet are virtual
[Android] How do I recover Uphold verified account after browser is reinstalled?
0 BAT after Restoring Wallet
Lost over 200 BAT
Wallet restore isn't working
Did I lose my rewards?
Tokens perdidos despues de reinstalar
Brave Reward Missing
Reward Missing after reward bug
I lost some of my estimated BAT rewards
Question about common-rewards-issues-work-in-progress
None of the BAT I have in my Brave Rewards account is going to my uphold wallet
Lost BAT rewards
Brave Rewards Lost/Disappeared After Restore Wallet
Can I recover my Brave rewards after formatting my laptop?
my bat does not appear someone help me
Unable to withdraw payments anymore
No ads are coming from the last 3 days in Windows
Brave Rewards Wallet recovery
Miss Brave rewards already gathered after format
