Need some details,
- Which country are you accessing from?
- Which website causing issues.
- Which extensions enabled
- Browser version/OS
- Disabled VPN?
- Cloudflare Ray ID Number?
Need some details,
March 19, 2025 Wednesday
Seemed to be fixed back in February, but since . . . I get the following when using Brave Search Engine Operators such as: news site:ie
As the problem still persists, I thought that I list my extensions:
The Cloudflare verification was working with these extensions before. I can’t identify which Brave upgrade was the critical one since I lost the CF functionality.
And yes, it IS hugely maddening to copy the links constantly and pasting them into a new private window…
Does CF work better without these extensions enabled? I don’t think its anything Brave has done. CF can change their checks on their servers and people assuming its Brave or concededly a recent Brave update causing issues. The less extensions the better tbh.
For myself, only time I get more CF checks is when using a VPN. Its not locked down, just adds more CF checks to some sites.
“I don’t care about cookies” is a dead extension, and hasn’t been updated. Also the functionality is built-in in Brave. Not sure about the rest.
It’s not working for me on Beta but works on Nightly.
mobile is work.
but pc dont work, how to add web from whitelist? from brave settings.. i dont found settings, my portuguese is bad languagem from settings
i found guide: https://developers.cloudflare.com/cloudflare-challenges/reference/supported-browsers/ … dont support brave browser ![]()
