Changing "On startup" in settings crashes Brave
Changing the On startup settings to either Open the New Tab Page or Open a specific page or set of pages crashes Brave on startup.
The only way to fix this issue is to delete Brave-Browser folder in Application Support.
MacOS Mojave (10.14.6) Brave (1.3.118) & Brave Beta (1.5.96)
@barfburglar,
Can you try clearing your browser cache/data and see if you get different results?
No, that doesn’t work. (I just did a Clear browsing data for All time and it crashes if i select any other On startup option outside of the default Continue where you left off.)
Typically, i delete Brave’s application support folder to get it to start up again, then it’s fine… it’s just that switch that crashes it.
@barfburglar,
Do you have any extensions installed in the browser at this time?
i’ve disabled extensions and the same issue persists.
