v 1.70.80
Cast no longer under the more tools section of the menu, media router is enabled in the settings.
v 1.70.80
@arottenmind whenever you notice something missing, it’s generally a good idea to look around. When I saw your topic, I looked and when I saw on Nightly that it wasn’t in the usual place, I just checked other things and found it.
So it’s under Save and share instead of More Tools.
Why? You may ask
The answer is because Chrome/Chromium moved it there and Brave inherited it.
Awesome thanks! I eventually found after I posted, you can also access it by right-clicking on the website background, and its in that popup menu as well!
Same to you. Hadn’t messed with Nightly much so didn’t know about it appearing when you right click the screen as well. Definitely good to know. Thanks for sharing.
