I can’t log in to Canvas for school randomly.
- I downloaded the latest Brave Relase, not the Beta or Nightly
2 Works with Safari.
3 Doesn’t work in a Private Window. - Also doesn’t work on iPad.
Anyone know what’s going on?
Does disabling Shields make a difference?
No, it does not. Is there any data I can obtain for you to help you diagnose the situation? I’m not too technical, but I’ll try my best.
I have to log in to Canvas from my school’s authentication portal if that helps.
