Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
- How do I opt into Brave Ads?
- Why am I not seeing Brave Ads?
- Windows 10 Ads Troubleshooting
- Rewards FAQ
Briefly describe your issue:
should be able to verify wallet but it just goes through login and authentication then does nothing
Android nightly 1.34.35
no
Are you using a VPN? (yes/no)
no VPN
California
yep passes sn
I think I have turned off auto contribute
