Can't connect to uphold using brave
Hello, I see I have reached max limit of veryfying uphold wallet, but I want to know is there any way to remove all the connection / reset all connections , so I can connect with uphold , I desperately need to do so in order to withdraw my bat ,
Any help will be appreciated
You can remove up to 1 device using this Unable to re-verify wallet - #118 by Mattches
Sent the form, but issue is that currently my geminin wallet is linked and rest I have no linked on, however I added my uphold wallet addresses, want to know in how many days can I expect the solution(removal of 1 device)
Btw thanks for the suggestions
The rest of the devices if you no longer have access to they will just delete 1. For the amount of days it can take, this could be quite a while as a lot of people are requesting this now.
Any work arround like linking new uphold wallet?
Hi @Devloperhs welcome to Community :smiley:
We are currently working on a wallet limit fix, stay tuned until that is released.
