Description of the issue: When I add Brave Search as a search engine in the iOS browser, I can select it as the default for standard tabs, but it does not show up in the list for private tabs.
- Add custom search engine and add Brave Search.
- Change “Standard Tab” search engine to Brave Search (works correctly)
- Go to “Private Tab”—no option for Brave
Expected result: Brave is listed as an option for a search engine for Private Tabs
Brave Version( check About Brave): Version 1.25.1 (21.5.21.22)
Mobile Device details
iOS 14.4.2, iPhone 11 Pro
