Description of the issue: Add block component does not update in regular or admin mode. On same pages for example Youtube, it doesn’t block ad-s. I also had chrome extension for blocks but that made the browser completely un-useable. It was extremely slow and on the edge of crashing all the time. The updating issue has been present on and off since January.
Exact URL of the website in question: Youtube, Asurascans
- when playing a youtube video
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? Yes, with ads.
Does the ad appear when using a Private window as well? (yes/no) Yes
What OS are you using when you see the ad? Windows 11
**Brave version (check About Brave):**1.80.115
