BSC & Polygon Chain. Buggy. Cant pay for gas fee
The new upgraded wallet is buggy in polygon & BSC chain. i cant do transactions even i have sufficient for gas fee. please get this resolve else the wallet is useless!
balance in wallet
transaction
when i click confirm. it states insufficient balance.
+1 had this happen on BSC when removing tokens from LP
Issue logged https://github.com/brave/brave-browser/issues/19536
I’m having the same problem. I need a quick solution
hopefully this can be resolved soonest as we are unable to do anything with the funds in the wallet. Anyway BSC chain has the same issue as well.
Avax network as well. cant pay for gas eth at all,
Hello folks.
We have identified the root cause of the issue as erroneously creating and signing EIP-1559 (Type-2) transactions for Polygon, BSC, AVAX, and others, which only support legacy transactions. We are working on a fix ASAP, and will keep this thread posted with any updates.
Note that Polygon (or others) transactions initiated from the Brave wallet are not impacted by this bug.
Thanks for your cooperation.
Still do not get the solution? I have to use my funds and I can’t. This should be quickly fixed.
I am getting the same problem. I can’t do any transactions on Quickswap(Polygon chain). Keeps telling me I have insuffucuent funds, when it’s obvious that I do have them.
some L2 sites are working, Like I can “claim” farming rewards on some L2 sites. But swapping on a DEX IS NOT WORKING. This is a big problem. I cant effectively make any trades. Definitely not trying any bridges right now. please fix
Hi onyb, any updates? is there a quick solution of this? its very damaging not to be able to do any transactions…
Any updates? Timeframe perhaps, any ETA?
Unable to transfer out of Brave wallet and transactions stuck in list, also please advise how do i change the noune so do clear off the transactions as cancelling doesnt work at all.
cannot cancel transaction.
Unable to unstake in https://dapp.klimadao.finance/#/stake.
Fix has landed on master so should probably be available in the next hotfix once its uplifted.
And when would that be?
Seriously, this is getting very frustrating. I cant approve the transactions in BSC for Bscpad resales for the 2nd time and cant send tokens out of brave wallet till now! 17-22 Nov. 5 days have past. how long are we still gona to wait?
It’s a fkin joke I feel so betrayed and losing trust.
Never using Brave wallet or the browser again, don’t care that these guys are adding Solana.
I wonder if they even did real testing how can something like this even happen when peoples funds are on the line?
thanks brave i still can’t make transactions
falla de brave
This should be working with today’s hotfix (1.32.113). Could you try updating and reply back? Thank you!
Good evening I confirm that the update fixes the error for the BSC network.
