Hey,
i want to scroll through the tabs of Brave very fast with my touchpad (i am using macbook pro). In Firefox, only the tabs are moving from left to right so i can easily and fast access the tab i want. With mouse it works by mousewheel when the courser is on the tabs.
At Brave-Browser, it works similar. But instead of scrolling the tabs miniatures, i have to scroll throug every single tab instead. This takes time…
Can you add an option, so i can scroll the way i want?
I love your browser, your project. But this is a serious issue for my due to slowing down my workflow massively.
Thanks for answers or - even better - a quick tipp how to change this <3
NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
