BraveBrowser does not print - Linux OS PDF download n print issues
Brave doesnt’t send prints to the printer, it does not download pdfs, it does not print pages to pdf. I use Parrot Security 6.3
  1. Printing with the browser menu or the system dialogue. Print is not executed.
  2. Downloading a pdf. Download dialogue is working, but no download is executed
  3. Printing page to pdf: Printing dialogue aks where to save the generated file. Submitted. Then, the dialogue starts again.
  4. Everything works fine with firefox.
  5. No firewall issues: Doesn’t work although the firewall is disabled
  6. de- and reinstallation of brave browser did not help
Expected result: prints should be executed
**Brave Version( check About Brave):**Version 1.77.95 Chromium: 135.0.7049.52 (Offizieller Build) (64-Bit)
@beijingbarry
Much to study at the following, but first try a fix that worked for some Linux OS users:
Download fails silently after choosing location to download - #27 by 20252025
Thank you very much for your advice. :folded_hands: The problem was solved with the last update I received right now.
