Hello
For the last month, I have had constant crashing when using my MacBook Pro. I have spent this time trying to troubleshoot the issue, but it appears to be Brave being the one causing these crashes.
I have used Firefox and Safari, and I do not have the same issues, but it appears to be only Brave that appears to do it.
The issue happens on a number of sites, so there is no specific site causing this. The crash reports also don’t point to Brave, but more of a part of macOS, but brave is the only app causing this.
Here are some of the things I have tried:
- Reinstall Brave
- Disabled all extensions
- Disabled hardware acceleration
Disabling hardware acceleration has stopped these crashes, but I have noticed a decrease in animation performance and other animations on websites.
I do suspect that it has something to do with my GPU of the MacBook Pro (crash reports don’t point to Brave), but since this is only happening on Brave, I thought it would be good to raise this first, before contacting Apple Support.
Steps to Reproduce
1 ) Open Brave
2) If not already enabled, turn on the hardware acceleration option.
3) After some time (1 hour, to a couple of hours), clicking a tab will freeze macOS
4) After 25 - 30 seconds, macOS will restart and boot up again.
No screenshots or video available due to the random nature of it.
Not to crash
Every couple of hours, sometimes when waking up from sleep, sometimes days.
Operating System and Brave Version
Device
MacBook Pro 16-inch, 2019
macOS Bug Sur 11.2
Brave
Version 1.20.108 Chromium: 88.0.4324.182 (Official Build) (x86_64)
I have attached an image of a crash report (I have three in total available). I would attach txt files, but not allowed due to being a new user.
