Brave will not reauthorize with Uphold
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Briefly describe your issue: Went to check rewards and noticed I was disconnected. Tried signing in and proceeded to the Reauthorize where I receive error “Something went wrong. Please try again.” And I fail to login. Repeatedly.
@steeven
What Operating System and Brave version are you using (Menu --> About Brave)? Brave 1.35.100 Android 11
Is your browser wallet currently verified? (yes/no) YES
**Have you been able to successfully receive payments in the past?**YES
Tried to reinstall Brave and lost my current earnings. Please help!!!
You should not have tried to reinstall as this clears out any Brave data in your current installation.
Are you able to verify your wallet after iun/reinstalling?
No. Now I know better. Only a week in so rewards no worry but yes I believed I locked myself out. Everything was running good before this hiccup.
Can you please respond to this here?
I have had active and verified Uphold wallet on my android Brave browser. Since today it look like “not verified” and Brave ask for “reauthorize”. I do it, but i receive a popup error (something went wrong. Please try again). I’ve alredy contacted Uphold assistance, who check and confirm connection is valid.
I have two connection active, one on pc and one on Mobile
What Operating System and Brave version are you using ( Menu --> About Brave )?
Android
Is your browser wallet currently verified? (yes/no) No
What date did you verify your wallet? last time 08/02/2022 20:51
Have you been able to successfully receive payments in the past? yes
Are you in a supported region ([see here] (https://brave.com/transparency ) for list of supported regions)?
Yes, i’m In Italy
yes, just done
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? yes
Hi! I’ve solve it last night without unistall brave… Fault is a Brave incompatibility with Uphold app
Unistall the app Uphold from the phone, and repeate the “reauthorization” procedure logging in Uphold by browser.
Than, after the verification is complete, you can install uphold app again
No. Will need to remove a wallet.
