Brave browser will not launch after today’s update on MX Linux. I can’t tell you the version number because it won’t launch. Everything was fine until the update. Please let me know what other information I can provide.
@Amandaville can you check to download newest version of Brave again. They just released a new update a couple hours after you posted. I’m thinking perhaps you grabbed hold of update from a few days ago where there’s been some known issues.
Other thing to do is to try to see if you can open in private window.
Hello @Amandaville
after check if there any update as @Saoiray suggested and if it did not lunch then
you can get the version by running this command on your terminal brave-browser --version
also try to start brave using the command line brave-browser from the terminal and see if you get any error message
hope that help and have a nice day ![]()
does it launch but quickly shuts down again?
Requested GLES version (3.0) is greater than max supported (2, 0)
also line 48: 9501 segmentation fault.
happened when I ran beta, so I switched to stable. once stable got to 1.60 or so, it just stopped. Pureos on Librem 5. 4x ARM Cortex A53
