Brave wallet issues and browser not saving passwords
Description of the issue: When connecting to certain dapps seems to mainly be on zksync network i get issues connecting my wallet. For example it tells me metamask or coinbase is not installed when it is and the extension is turned on. I first ran into this problem on orbiter finance and thought it was a bug with orbiter because it was saying neither my metamask wallet or coinbase walet are installed and then if i would try to connect my brave wallet it would say that the meta mask wallet is interfering and to make sure to have the extension off and i had turned it off and removed it entirely with no luck. Previously orbiter had worked fine and i dont recall changing anything. I also had a similar issue yesterday on 1 inch where it was telling me that metamask wallet is not connected when it was. thanks for your time looking forward to some help.
Are you using the (new) Brave Wallet or the (old) Crypto wallets implementation? New i think?
Additional Information: Also have had issues recently with my passwords not saving… the passwords themselves save but i get signed out everytime. for example on gmail and other sites i use alot its nice when gmail saves the password so your gmail opens autoimatically to your mail recently i have to autofill both user and password everytime, thanks
Having same issues with Brave desktop wallet not working on any zksync era or lite/test dapps.
Can use the bridge, but can’t do anything with funds after the fact.
i guess bravewallet does not support zksync network…so from my understanding funds are stuck until then
@chedbob14 zksync issues have been fixed on the latest release of 1.52.x. Please let me know if you’re still having issues.
Details on my answer on another post if you’re interested. :point_down:
