Brave Wallet Crypto Withdrawal Solution
Description of the issue:Hello,
I’m new to Brave and have just discovered the crypto wallet feature. To test it out, I sent a small amount of BTC to the wallet.
I can see how to deposit crypto, but I can’t find any option to withdraw or sell them. I assume this is because I haven’t entered any bank details, but I can’t find where to do that. My goal is to be able to convert my crypto back to real money.
On another forum, someone suggested I should use a dApp to solve this. However, I’m very skeptical about this and feel like it could potentially be a scam. Could anyone clarify the standard procedure for withdrawing funds from the Brave Wallet? I’m a bit lost and would appreciate any guidance. Thank you.
Is the issue occurring on a specific network?
What operating system are you using?
Hello, thanks for reaching out! Some tokens will allow you to Sell within the wallet. This will use a partner off-ramp provider. It will depend on the token/network. If you don’t see the Sell option, it is likely not available for that specific token/network.
You can also send your crypto to an exchange and then convert to fiat and transfer it to your bank provider.
Sending crypto: https://support.brave.app/hc/en-us/articles/11300011354765-How-do-I-send-crypto-in-Brave-Wallet
