Brave v1.80.122 problems on MacOS 15.5
Brave was automatically upgraded to v1.80.122. I am using MacOS 15.5 and there have been no recent updates to MacOS.
Everything is slow or simply fails to render. This includes attempting to open a new browser tab in the same window, attempting to navigate to Brave → About Brave, and even attempting to send the numerous and recorded Crash Reports.
I’ve downloaded the latest Brave .dmg, reinstalled, and the problems still exist.
I am unable to send Crash Reports from brave:://crashes since they never finish sending after clicking on the Send Now button for each.
Update. It seems if I leave the Brave browser open for at least an hour (or so) then things are OK.
If I quit the Brave browser and open it again then the mentioned problems occur again.
Open a Terminal.app window, and enter:
  • open -a "Brave Browser.app" -n --args --disable-gpu --disable-extensions --no-experiments --enable-leak-detection --crash-on-failure --incognito
That command will start Brave Browser with Hardware Acceleration DISABLED, and using a New Private Window.
If BB running, then try brave://crashes
Location tip: /Applications/Utilities/Terminal.app
How do I manually submit crash reports?
https://support.brave.com/hc/en-us/articles/22281484910221-How-do-I-manually-submit-crash-reports
After you click the “Send Now” button, return to brave://crashes and gather up the Crash Report ID numbers that end with a string of zeros. Post the numbers, here, in a new reply. Example of a Crash Report ID number:
Thank you for this. The terminal command was helpful.
One of the many submitted Crash Reports:
15ad1300-27f1-2d0e-0000-000000000000
21991300-27f1-2d0e-0000-000000000000
be3e1300-27f1-2d0e-0000-000000000000
bd3e1300-27f1-2d0e-0000-000000000000
16351300-27f1-2d0e-0000-000000000000
4f2d1300-27f1-2d0e-0000-000000000000
39391300-27f1-2d0e-0000-000000000000
3d391300-27f1-2d0e-0000-000000000000
Additional comments…
No VPN was in use. My Internet connection was fine.
No shortage of processor/CPU, memory, or disk resources on my Mac.
No observable spike in processor/CPU or memory when opening Brave and it went into a form of slow/stalled mode. I have iStat Menus and can see excessive processor/CPU or memory utilization on my top desktop tool bar.
Thanks @atcclears, sending to the team for review.
My Brave browser was just upgraded to v1.80.124 and I’m observing the same problem(s). I thought I’d mention this out loud to the Brave dev team.
Crash Reports from v1.180.124
5dd60100-bf2d-370e-0000-000000000000
5cd60100-bf2d-370e-0000-000000000000
5ed60100-bf2d-370e-0000-000000000000
The problem(s) seem to be resolved with Brave v1.180.125
Thank you for the update! Glad to hear it’s resolved.
