Brave sync - Does not work at all and impossible to understand
Is Brave sync workng?
Impossible to setup and impossible to understand. Chrome is so much easier. Why Brave neede to complicate matters so much?
Hello there :wave:,
Yes, Brave Sync does work. Sometimes there are problems, yes, but most of the time it works flawlessly.
The configuration is also not that hard to do. There are only a few steps involved to get it to work.
Steps:
  • Go to brave://settings/braveSync in your address bar.
  • Create a new Sync Chain
  • Copy the words somewhere where it is safe, for example your password manager
  • Copy the words over or create a QR Code and scan it with your other phone, laptop or pc.
  • You’re done
When you need further or a deeper insight to set up this, let me know, I would try to assist you.
@Kavi,
Our documentation on Sync should help you understand how to set it up as well as how it works:
