Every time I try to do a search or type in a website, Brave suggestions pop up & will not delete to allow me to enter what I’m trying to search. I checked the settings & have suggestions turned off. And I hard closed & restarted Brave. It’s still not allowing me to enter what I want or delete suggestions. Please help. I’m having to go to a different browser to look up things.
system
Closed
2
Related topics
| suggestions when searching on Brave Search | 11 | 243 | January 22, 2026 | |
| Disable Search Suggestions | 5 | 199 | November 30, 2024 | |
| How do I turn off the search suggestion in the address bar | 39 | 12433 | April 17, 2023 | |
| Switching off Google Suggestions does not work | 11 | 4497 | May 7, 2022 | |
| Thank you - how do you disable adress field auto suggestions from supposed search engine? | 0 | 355 | June 21, 2021 | |
| Removal of the unrequested from Brave Browser | 1 | 125 | March 20, 2024 | |
| How do I get rid of this annoying search suggestion that's really unhelpful? | 3 | 3465 | March 5, 2025 | |
| Stopping autocomplete in search fields on sites | 5 | 3962 | February 15, 2023 |
