Brave still starting with enable-crashpad
Brave writing small chunks every second to disk for --enable-crashpad. I guess that this is to support usage statistics but it is hell on my SSD. If there is not a workaround I’m dumping Brave.
  1. Start brave
    2.watch disk io
At least at the very least you could cache the writes to reduce the number of writes. Do you REALLY need down to the second stats.
Version 1.37.109 Chromium: 100.0.4896.60 (Official Build) unknown (64-bit)
I see that there’s a firefox fork librewolf that looks interesting. I’m going to check that out.
@stephenboston
Test
Go to: brave://settings/privacy . . . and disable: Automatically send diagnostic reports
Been there/done that.
Has no effect. Here the iotop output for brave over two minutes.
10:05:35    4558 be/4 stephen     0.00 B/s    7.70 K/s  ?unavailable?  brave --enable-crashpad
10:05:36    4558 be/4 stephen     0.00 B/s    7.56 K/s  ?unavailable?  brave --enable-crashpad
10:05:37    4581 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:05:40    4558 be/4 stephen     0.00 B/s   15.07 K/s  ?unavailable?  brave --enable-crashpad
10:05:42    4558 be/4 stephen     0.00 B/s   15.13 K/s  ?unavailable?  brave --enable-crashpad
10:05:43    4558 be/4 stephen     0.00 B/s   15.10 K/s  ?unavailable?  brave --enable-crashpad
10:05:43    4636 be/4 stephen     0.00 B/s    3.77 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:05:43   15732 be/4 stephen     0.00 B/s    7.55 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:05:45    4558 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad
10:05:47    4558 be/4 stephen     0.00 B/s   38.95 K/s  ?unavailable?  brave --enable-crashpad
10:05:47    4581 be/4 stephen     0.00 B/s    3.90 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:05:47   15732 be/4 stephen     0.00 B/s    3.90 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:05:48    4558 be/4 stephen     0.00 B/s    3.79 K/s  ?unavailable?  brave --enable-crashpad
10:05:50    4558 be/4 stephen     0.00 B/s    7.70 K/s  ?unavailable?  brave --enable-crashpad
10:05:52    4558 be/4 stephen     0.00 B/s   45.27 K/s  ?unavailable?  brave --enable-crashpad
10:05:52    4636 be/4 stephen     0.00 B/s    3.77 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:05:52   15732 be/4 stephen     0.00 B/s    7.54 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:05:54    4558 be/4 stephen     0.00 B/s    7.55 K/s  ?unavailable?  brave --enable-crashpad
10:05:57    4581 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:01    4558 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad
10:06:04    4558 be/4 stephen     0.00 B/s    7.70 K/s  ?unavailable?  brave --enable-crashpad
10:06:06    4558 be/4 stephen     0.00 B/s    7.70 K/s  ?unavailable?  brave --enable-crashpad
10:06:07    4581 be/4 stephen     0.00 B/s    3.84 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:08    4558 be/4 stephen     0.00 B/s   37.64 K/s  ?unavailable?  brave --enable-crashpad
10:06:08    4636 be/4 stephen     0.00 B/s    3.76 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:06:08   15732 be/4 stephen     0.00 B/s    7.53 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:11    4558 be/4 stephen     0.00 B/s   18.96 K/s  ?unavailable?  brave --enable-crashpad
10:06:17    4558 be/4 stephen     0.00 B/s    7.55 K/s  ?unavailable?  brave --enable-crashpad
10:06:17    4581 be/4 stephen     0.00 B/s    3.78 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:18    4558 be/4 stephen     0.00 B/s   18.88 K/s  ?unavailable?  brave --enable-crashpad
10:06:19    4558 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad
10:06:20    4558 be/4 stephen     0.00 B/s    7.59 K/s  ?unavailable?  brave --enable-crashpad
10:06:21    4558 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad
10:06:21   15540 be/4 stephen     0.00 B/s   11.55 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:22    4558 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad
10:06:24    4558 be/4 stephen     0.00 B/s    7.54 K/s  ?unavailable?  brave --enable-crashpad
10:06:27    4558 be/4 stephen     0.00 B/s   34.62 K/s  ?unavailable?  brave --enable-crashpad
10:06:27    4581 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:27    4587 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad [Chrome_IOThread]
10:06:27    4636 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:06:27   15540 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:28    4558 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad
10:06:32    4558 be/4 stephen     0.00 B/s    7.67 K/s  ?unavailable?  brave --enable-crashpad
10:06:33    4558 be/4 stephen     0.00 B/s   30.23 K/s  ?unavailable?  brave --enable-crashpad
10:06:33    4636 be/4 stephen     0.00 B/s    3.78 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:06:33   15540 be/4 stephen     0.00 B/s    7.56 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:35    4558 be/4 stephen     0.00 B/s    7.70 K/s  ?unavailable?  brave --enable-crashpad
10:06:37    4581 be/4 stephen     0.00 B/s    3.79 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:38    4558 be/4 stephen     0.00 B/s    7.55 K/s  ?unavailable?  brave --enable-crashpad
10:06:40    4558 be/4 stephen     0.00 B/s  100.21 K/s  ?unavailable?  brave --enable-crashpad
10:06:40   15540 be/4 stephen     0.00 B/s    7.71 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:43    4558 be/4 stephen     0.00 B/s    7.70 K/s  ?unavailable?  brave --enable-crashpad
10:06:44    4558 be/4 stephen     0.00 B/s    7.67 K/s  ?unavailable?  brave --enable-crashpad
10:06:47    4558 be/4 stephen     0.00 B/s   19.24 K/s  ?unavailable?  brave --enable-crashpad
10:06:47    4581 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:47   15540 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:48    4558 be/4 stephen     0.00 B/s   15.39 K/s  ?unavailable?  brave --enable-crashpad
10:06:49    4558 be/4 stephen     0.00 B/s    3.78 K/s  ?unavailable?  brave --enable-crashpad
10:06:49    4678 be/4 stephen     0.00 B/s    3.78 K/s  ?unavailable?  brave --enable-crashpad [CacheThread_Blo]
10:06:51    4558 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad
10:06:51   15540 be/4 stephen     0.00 B/s   11.54 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:52    4558 be/4 stephen     0.00 B/s   30.20 K/s  ?unavailable?  brave --enable-crashpad
10:06:52    4636 be/4 stephen     0.00 B/s    3.78 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:06:52   15540 be/4 stephen     0.00 B/s    7.55 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:06:53    4558 be/4 stephen     0.00 B/s   18.93 K/s  ?unavailable?  brave --enable-crashpad
10:06:55    4558 be/4 stephen     0.00 B/s    7.83 K/s  ?unavailable?  brave --enable-crashpad
10:06:57    4558 be/4 stephen     0.00 B/s    7.58 K/s  ?unavailable?  brave --enable-crashpad
10:06:57    4581 be/4 stephen     0.00 B/s    3.79 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:06:58    4558 be/4 stephen     0.00 B/s   30.76 K/s  ?unavailable?  brave --enable-crashpad
10:06:58    4636 be/4 stephen     0.00 B/s    3.84 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolSingl]
10:06:58   15540 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad [ThreadPoolForeg]
10:07:00    4558 be/4 stephen     0.00 B/s    7.56 K/s  ?unavailable?  brave --enable-crashpad
10:07:03    4558 be/4 stephen     0.00 B/s    7.54 K/s  ?unavailable?  brave --enable-crashpad
10:07:04    4558 be/4 stephen     0.00 B/s    7.54 K/s  ?unavailable?  brave --enable-crashpad
10:07:07    4581 be/4 stephen     0.00 B/s    3.85 K/s  ?unavailable?  brave --enable-crashpad [HangWatcher]
10:07:08    4558 be/4 stephen     0.00 B/s    7.69 K/s  ?unavailable?  brave --enable-crashpad
@stephenboston
Looking around for what might help . . .
Discovered: brave://tracing/ (but have not used it)
Found that (‘chrome://tracing’ actually), at: https://github.com/gorhill/uBlock/issues/1788
metrics
/ . . . /BraveSoftware/Brave-Browser/Local State
Local State file - 5 parts mentioning the word: ‘metrics’
(The last of the 5 parts, there, mentions: ‘user_experience_metrics’
/ . . . /BraveSoftware/Brave-Browser/Default/Preferences
Preferences file - 4 parts mentioning the word: ‘metrics’
Chome parameters - 3 mentions of ‘crashpad’
‘https://programmersought.com/article/70288998872/’
But, it looks like, in your ‘iotop’ display, that Brave Browser for Linux OS, has not a bug, but a pest.
Take a look at: ‘https://github.com/brave/brave-browser/issues?q=enable-crashpad+is%3Aissue+sort%3Aupdated-desc+’
Screen Shot 2022-05-28 at 6.52.52 PM
