Brave is up to date: Version 1.38.111 Chromium: 101.0.4951.54 (Official Build) (64-bit)
Windows 10 PC. The shield settings are all default, yet the shield is off by default for every new page I visit. Why is this? It makes this browser pointless.
That’s weird. I have same set up as you but shields are up by default. Hope someone helps you out.
This solution via Reddit solved the problem for me:
Settings > Privacy and security > Clear browsing data > Advanced > Site and Shields Settings
Clear it for all time .
@lastgasp, worked for me as well, thanks for sharing.
This worked for me as well. Thank you.
And here’s a follow-up suggestion courtesy of @ 289wk
Once the GLOBAL default is restored: Shields UP
Then, remember to return to:
brave://settings/clearBrowserDataand:
- Set ‘Time range’ to:
All time- Disable:
Site and Shields Settings. . . so Shield settings will again be remembered.
