Hello, for 10 months I have received my rewards usually from the 8th -10th of a month. I waited an extra day and the status of Uphold is “Payments Complete” I only received my rewards from 1 device this time.
Windows 10 Pro,
Version 1.34.80 Chromium: 97.0.4692.71 (Official Build) (64-bit)
**Is your browser wallet currently verified? yes
What date did you verify your wallet? Feb 2021
Have you been able to successfully receive payments in the past? Yes
**Are you using a VPN? no
**Are you in a supported region yes , (Canada)
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? Yes, even if it was ON I made at least 3 BAT and Auto is defaulted to 1 BAT (should still receive 2 BAT)
