[Brave rewards] Is not possible send tip to creators
If you go to brave://rewards you will see a card where is the amount of BAT earned 'cause the Ads.
but , if you click in the BAT logo, in the navigation bar the 3.3 BAT are not showing it. For this reason is not possible to send tip to creators.
What is the reason of this?
Thanks!
@ann0nip
Estimated BATs (your 3.3 BAT) are paid out once a month, about the 5th of each month. So you do not get them until then. And then you can use them for tips.
Ohh I see! and when the BATs are paid they will be ready to use as tips even though I didn’t add a verified wallet?
Thanks for your answer
@ann0nip
Yes, you can use the BAT for tips even though you didn’t add a verified wallet. You do not have to have a verified wallet.
Very clear! Thank you so much!
-Ann0nIp
