Brave Pop Ups upper right hand corner of screen
I have asked this before, and one response but no answer.
Here is what was on my previous post:
Upper right-hand corner of screen pop-ups.
Pop-ups are from Brave.
How do I stop them?
Mac Mini macOS Ventura 13.2.1
As far as I know, latest version, this is what comes up on about Brave: Brave is up to date
Version 1.50.114 Chromium: 112.0.5615.49 (Official Build) (x86_64)
Yes, desktop computer and the above is what I just downloaded as the most recent.
The above was my response to one answer that I received.
This issue has not been corrected.
This very annoying and the pop-ups don’t go away, I have to manually delete them.
Could someone please give me a solution?
Thank you.
@lvbassist You’re referring to notifications? If so, I’m guessing you’re seeing the ads from Brave Rewards. If you aren’t wanting to use Rewards, you can just go to brave://rewards and turn it off or you can dive into settings to change how often they appear.
When you say pop-ups, you’re not referring to a website opening, are you? Perhaps, can you share a screenshot of what you’re seeing?
That is definitely not the latest. 1.50.114 was released on April 5 . The newest version of Brave is 1.51.118.
