Description of the issue: My search settings (display language, search preferences, etc) aren’t being saved. I’ve made sure that the website data isn’t being shredded when I close the page, but it doesn’t change anything. I just recently updated the app, so I’m assuming it’s coming from that.
Hello @Stobe - thank you for surfacing this! One of my teammates did some testing, because it appeared (initially) that their settings were also not being retained.
Could I have you re-check your ‘About Brave’ just to ensure there are no further updates available (I don’t believe there are, but it can’t hurt to check), then try the following?:
Change region, light mode, safe search
Close tab, then browser
Relaunch, then visit search.brave.com to see if the settings you altered were retained?
Settings adjustments may not/will not stick when using a Brave Browser Private Window in order to make those changes at https://search.brave.com/settings. The adjustments are lost when closing such a window.
