Credentials not being saved so that I have to enter username and password on each visit.
Also, the ‘saved’ password, seen as *****, is not the correct password.
1.Login to Site A
2. Fill in password, choose save password
3. Enter Site B
4. Return to Site A. Am prompted again for credentials and accepting stored credentials gives a login failure.
Previous behavior: Login to A, go to B, return to A – without being prompted for credentials
Version 1.10.97 Chromium: 83.0.4103.116 (Official Build) (64-bit)
This has persisted over the last couple days. I have to re-enter manually username and password at sites that usually I can access without being challenged. For sites on which I have kept the same password for a year or so, this is not a problem.
