Brave not connecting to uphold
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Briefly describe your issue:
Brave not connecting to uphold and signing in to uphold.
Says log into uphold to see your balance and it is just spinning.
1.64.122
Android 11
Is your Brave Rewards Profile currently verified? (yes/no)
Not sure. I haven’t had issues for a while.
Been a long while
Yes
Are you using a VPN? (yes/no)
No
Are you in a supported region ([see here] yes
(https://support.brave.com/hc/en-us/articles/6539887971469-Supported-regions-for-verifying-Brave-Rewards-with-a-custodial-account-provider-) for list of supported regions)?
Yes Florida
Not sure but haven’t had any issues
Have you fully completed Uphold’s CDD requirements?
Been using uphold for a while. And can log into uphold
Hello! Do you have the Uphold app installed? If so, would you mind removing it and trying to verify with the Brave browser instead? Thanks for confirming.
Ok yes I do have the app
I will try
That worked with uninstalling uphold app
Never isn’t verying my wallet again.
I have gone thru a couple times and won’t take.
@airplanelane current issue is as mentioned at topic below:
Thank you for your response.
Just tried to reconnect and still unable to connect to brave after verifying and opening uphold.
@airplanelane I know. If you looked at the topic I linked to I said nobody can connect right now and we are waiting for them to fix the connection
And if read through comments there would see:
So just have to hang tight until they advise it’s fixed
