Latest nightly:
Version 1.28.17 Chromium: 91.0.4472.114 (Official Build) nightly (x86_64)
After updating today, I received the normal update prompt:
“Nearly up to date! Relaunch Brave to finish updating. Private windows won’t reopen.”
However, I’m stuck at the “Relaunch” prompt in the About Brave section of the settings menu. Clicking on “Relaunch” does not do anything. Manually closing and relaunching the Nightly build does not fix this issue.
              It’s a bug, should be fixed soon.
        opened 03:44AM - 22 Jun 21 UTC
        OS/Desktop
        OS/macOS
        bug
        priority/P1
        regression
    <!-- Have you searched for similar issues? Before submitting this issue, please … check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
## Steps to Reproduce
   1.  clean profile
   2. launch Brave
   3. go to `Brave` `About Brave`
   4. click the `Relaunch` button
## Actual result:
Nothing happens
## Expected result:
Browser should restart/relaunch w/update
## Reproduces how often:
100%
## Brave version (brave://version info)
`1.28.17 Chromium: 91.0.4472.114 (Official Build) nightly (x86_64)`
              More on this. Still…
macOS 10.15.7
Brave Nightly (just updated to) 1.28.54 64-bit.
Not relaunching and just silently crashing (2 sec main menu flash).
