Brave Leo does not summarises videos correctly on two separate t abs
Leo does not summarise the video instead summarises Brave browser.
Open two Youtube Videos on two seperate tabs
Open Leo and make it summarise the video on both tabs one after the other
One of the videos on one tab is summarised correctly
Second tab which is summarising parallel summarises Brave browser instead instead of the Video given to summarise.
Expected R esult:
Both videos with good summaries.
Always
Brave release - v1.62.165
Yes
Additional information:
I’m using Windows 11 Latest
I’m 99% that this is what happens: Youtube is not a regular web page, it’s a web app at this point. When you open a video, it doesn’t reload the whole page, it only reloads parts of it. For whatever reason Leo is unable to see the newly loaded parts and is trying to summarize whatever was the first youtube page that you loaded into a tab.
You can work around this issue by refreshing the tab (press F5 or the refresh button on the top left) before opening Leo to summarize it. Try it and tell me if it didn’t work.
But yes a proper fix is needed for this though I have no clue how hard it would be to implement.
Hi there,
I have brought this to the attention of our team to inquire if this is a known ‘issue’.
Will update once I hear more!
Update: This is a known issue and our team are working to implement a fix soon.
Thanks for your patience!
