Brave lagging/freezing when scrolling
Brave lagging/freezing when scrolling. It happens a few times per 5 minutes
Just open any website and scroll down
Expected R esult:
No freezing
Always
Brave release - 1.36.119
Yes
Additional information:
Windows 10 64b
It can be fixed by switching off hardware acceleration, but I need that option
@levider,
Thank you for reaching out. Can I ask why you need HWA enabled?
Web online games and other flash stuff
Without hwa it’s very laggy and unplayable
Unfortunately I’m not sure there’s a ton we can do here at this time. I have a feeling you’ve already checked this but just in case, you might check and ensure that your drivers are all up to date. Alternatively, you can try removing all drivers, then letting Windows find the latest/best drivers automatically, then test and see if this makes any difference.
Everything is updated. Maybe future updates of Brave will fix the problem
