Brave is not opening some sites when mobile data is on, but it is opening when wifi is on
Hi! Brave on mobile is opening some sites when WIFI is on, but the same site it is not opening when mobile data is on.
Please sort it out for me.
that can’t be correct it is probably network provider. send some of these links.
these are porn sites.
@mnbhangar,
Thanks for not sending them in – smart move!
That said, I think that @Dgenies is correct in that this isn’t dependant on Brave but rather network/system settings on your device.
What kind of device are you using?
