Brave flickering while hardware acceleration is turned on
Description of the issue: The browser quickly flickers randomly on any website
  1. Launch Brave with Hardware Acceleration turned on
Expected result: No flickering is observed during use while Hardware Acceleration is turned on
Brave Version( check About Brave): Version 1.20.108 Chromium: 88.0.4324.182 (Official Build) (64-bit)
Turning off Hardware Acceleration stops the flickering but causes dropped frames in 60fps and high quality (4k and above) YouTube videos and on 60fps Twitch streams.
GPU: RTX 3080
Driver version: 461.40
CPU: i9-9900KF
OS: Windows 10 Pro 20H2 Build 19042.804
Having the same issue I too have a RTX 3080
Same problem… It’s terrible. Please fix that ASAP dear devs!
